Ethernet Products
5821 Discussions
Converting example from using TCP/IP to UDP
I adapted the example "Nios II Ethernet Simple Socket Server
on MAX 10 FPGA Development Kit" to send data from a MAX 10 board
to a PC with Matlab. The datarate I get is about 5 Mbyte/s
with TCP/IP.
Is is simple to change the code to use the faster UDP in stead
of TCP/IP? This was suggested by reading that TCP/IP uses
the send command, while UDP uses sendto. I hope for a
simple command substitution :).
Jos
hi you used the example on matlab !!!? can you tell me how you did that or provide suggestions on how to start with it am using the example but on nios 2.
my board is Stratix IV
--- Quote Start ---
--- Quote End ---
In Matlab I open the connection with:
TCPIP_Handle= tcpip(RadarIPAddress, Port, 'NetworkRole', 'client')
fopen(TCPIP_Handle)
Use the appropriate address and port.
On the MAX 10 side I adapted the file simple_socket_server.c, not using DHCP
(BSP setting) and using a fixed IP adress (simple_socket_server.h).
Probably I forgot some things. My experience is that you have to
experiment yourself quite a bit before things work. Most important
is that you know now that it can be done.
--- Quote Start ---
fopen(TCPIP_Handle)
--- Quote End ---
so your simple socket worked fine on your board ? as when I did the simple socket I encountered problems but the webserver works fine but I cant start a telnet session I don't really know why ,
do you still have the codes if it is possible to share it with me ?
--- Quote Start ---
--- Quote End ---
Yes, it works fine. Unfortunately, I cannot share the code with you, because
I developed it for a commercial project.
Jos
Alrtight can you help me figure out why it doesn't work,
I tried all the possible ways !!! my webserver works !!! and ping can be established!!! but the telnet session doesn't work !!??? any idea !!
please help !!
though the webserver and ping works fine I have this error
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prepped 1 interface, initializing...
mctest init called
IP address of : 192.168.1.66
dtrap - needs breakpoint
Error sending DHCP packet on iface 0.
ip_exit: calling func 0x1801b6f0
ip_exit: calling func 0x18023298
Attached shows the web server and the ping working successfully
You use DHCP. I use fixed IP addresses. Also do not forget
to disable an eventual fire wall.
--- Quote Start ---
--- Quote End ---
Also when i tried without DHCP, the telnet session did not work
