In this thread the XL710 J3 jumper is mentioned:
I found two types of jumpers:
closed:
https://www.google.com/imgres?imgurl=https://cdn.sparkfun.com//assets/parts/2/4/0/7/09044-02-L.jpg&imgrefurl=https://www.sparkfun.com/products/9044&docid=970qvGPxp6UYVM&tbnid=VswzLEwkGLUwcM:&vet=1&w=600&h=600&bih=471&biw=1093&q=closed%20jumper%20PC&ved=0ahUKEwiuwJqy1fbQAhVBkRQKHRLbDDAQMwghKAYwBg&iact=mrc&uact=8 https://www.google.com/imgres?imgurl=https://cdn.sparkfun.com//assets/parts/2/4/0/7/09044-02-L.jpg…
Opened:
https://www.google.com/imgres?imgurl=http://i.ebayimg.com/images/g/-IkAAOxyTMdTPUz1/s-l300.jpg&imgrefurl=http://www.ebay.com/itm/10x-IDE-HDD-PC-2-Pin-Jumper-Plug-Black-short-circuit-bridge-Jumper-Black-/281771240561&docid=ECgpXUnvKFtZwM&tbnid=IQr3KNauz-fOaM:&vet=1&w=300&h=218&bih=471&biw=1093&q=closed%20jumper%20PC&ved=0ahUKEwiuwJqy1fbQAhVBkRQKHRLb... https://www.google.com/imgres?imgurl=http://i.ebayimg.com/images/g/-IkAAOxyTMdTPUz1/s-l300.jpg&imgrefurl=h…
Both fit XL710 J3 .
Will both types work for XL710 J3 ? is there any significant difference between them ?
Or only one of them should be used?
HI KevinW,
Thank you for the post. What is the purpose of using the jumper on the XL710 ? Are you referring to XL 710 standalone network adapter? can you provide the exact model of XL710?
Rgds,
wb
Hi Kevin W,
Please feel free to provide the information.
Rgds,
wb
