Ethernet Products
4529 Discussions
Could not install ANS Teaming software
I am using Intel(R) PRO/1000 P Dual Port Server Adapter on windows 2008 server. Driver for Intel(R) PRO/1000 P Dual Port Server Adapter has sucessfully installed and running fine. But while I am trying to Install ANS teaming Software. I am getting below error.
"Cannot install drivesr. no Intel adapters are present in this computer"
On windows 2003 I am able to install without any errror.
Mark_H_Intel
Is your OS Windows Server 2008 R2 or Windows Server 2008? If you are using Windows Server 2008 R2, the Intel(R) Network Connections software does not have any drivers for the Intel(R) PRO/1000 P Dual Port Server Adapter. The only drivers available are the basic drivers supplied by Microsoft with the OS.
You could add the ports to a team if you installed one of the newer adapters that has full support for Windows Server 2008 R2 and created a team using one of the ports on the newer adapter. See http://www.intel.com/support/network/sb/CS-030614.htm Is my Intel® Ethernet Adapter supported in Microsoft Windows Server 2008 R2*? for a list of adapters with full support.
Mark H
