Ethernet Products
5821 Discussions
Creation of Team failure using the Intel PRO/1000 EB Network Connection
I am facing a problem while creating the team using the LAN adapters can anyone help.
I have installed the following LAN adapters
i) Intel(R) PRO/1000 EB Network Connection with I/O Acceleration
ii) Intel(R) PRO/1000 MT Dual Port Server Adapter.
OS: Windows Server 2008
I have performed the following steps:
i) Open the properties of "Intel(R) PRO/1000 EB Network Connection with I/O Acceleration" in "Device Manager".
II) Select the Teaming Tab
iii) Create the Teaming using the above specified Intel PRO LAN Adapters.
iV) It is showing the error message as "Cannot create the Team".
Thanks in advance.
Nambirajan .J
SDeb
Hi Nambirajan,
Even i am also unable to teaming the existing two Intel PRO/1000EB from properties --> Configure --> ANS Teaming. It is not taking the IP address. Did you have any idea??
-Sabarna
