Does anyone know if the DPDK Intel ICE driver has or will have support for TX-Send-On-Timestamp capability similar to that in the DPDK Mellnox 5 driver ? We have very strict timing requirements for our TDM transceiver and have had good results with the DPDK mlx5 driver. We were hoping the Intel E810 might provide the same support. Thanks for any help or information you could provide.
Hello @KMAbside,
For this particular issue, kindly reach out DPDK.org or open an IPS case at IPS Support.
Please refer the link below on how to reach the IPS support
How to Register and have Access to Intel® Premier Support
Thank you.
BY_Intel
Intel Customer Support
Hi @KMAbside ,
Would you mind telling me about your running environment ?
I'm having some trouble in running a DPDK application('generator' module in the repo) from 5t5g repo(https://github.com/NVIDIA/5t5g) on a linux server with Mellanox5 driver.
Here is my configuration.
a. Server/OS : a Dell Server with Red Hat Linux 8.8
b. CPU : Mellanox ConnectX-6 Dx Dual Port 100 GbE QSFP56 Network Adapter
c. NIC card : ConnectX-6 DX
d. NIC firmware : MLNX_OFED_LINUX-23.07-0.5.1.2-rhel8.8-x86_64.iso
e. port configuration : loopback (port 0 tx -> port 1 rx, port 1 tx -> port 0 rx)
I'm not sure whether it is coming from "a failure in sync PTP clock to a grandmaster(we don't have a PTP grandmaster or an ethernet switch in the network)" or "a compatibility issue between 5t5g and other software, such as DPDK".
I'm looking forward to hearing from you.
Kind regards,
Kevin
Hi Kevin,
This is really an Intel forum .. but anyway. If you're running mlx5 or 6, you will need to install the MLNX_OFED libraries and might want to build the DPDK. We run on Ubuntu 20.04 and download this: MLNX_OFED_LINUX-5.5-1.0.3.2-ubuntu20.04-x86_64.tgz. Untar and run mlnxofedinstall. If you google around you may find one for RHEL. We also build the DPDK. We download dpdk-21.05.tgz, untar and do meson build, ninja, ninja install. I have not used the dpdk generator, but have used the "testpmd" quite a bit to test out our links, data transfers, etc. The DPDK documentation has a fairly decent description of how to run the testpmd along with a bunch of arguments.
HTH,
KM
Hi KM,
Thank you for the reply.
I know this is Intel forum, however, I'm so desperate.
Another question for you is when you run it, did the server is synchronized to the grandmaster ?
I mean, because it is also an important aspect for me.
Thank you,
Kevin
