Ethernet Products
4875 Discussions
DPDK pktgen - environment set up for two mother boards
SLin27
I plan to run DPDK-pktgen on my Xeon D platform.
I have two MBs. Since i currently don't have 10G switch, my experiment is to use one MB to act as a 10G switch to generate traffic and the other one is to act as a receiver.
Each MB has two 10G port embedded. so total I have 4 10G ports and two on either one.
Below is my configuration:
OS: Ubuntu 16.04
CPU: Xeon-D 1541 & Xeon-D 1557
NIC: Intel X552/X557 10GBASE-T
My understanding is probably wrong, there might be better testing scenario for pktgen. If so, please kindly let me know.
If my testing scenario is reasonable, is there any document I can follow to set up the environment ?
Sam
Hi Sam_Lin,
Thank you for posting at Wired communities. For All Intel® DPDK questions and technical problems including those regarding the Ethernet* Controllers, please
visit the Intel® Premier Support site http://premier.intel.com/premier or access IBL account. Click the Intel® Premier Support link to enter issues under the Product Name "Data Plane Development Kit (DPDK)". Your inquiry will be forwarded to the appropriate support team and they will further assist you.
Hope the above information help.
sharon
SLin27
Should I just wait the reply here ? Or should I open a new ticket in IPS
Hi Sam_Lin,
Please open a ticket there at IPS to submit your inquiry there.
Thank you.
rgds,
sharon
SLin27
Hi Sharon,
okay, should I close the ticket here ? If so, how can I do it?
Sam
Hi Sam_Lin,
No worries I will be the one to close the case here. Thank you :)
rgds,
sharon
