Ethernet Products
4621 Discussions
Default rte_flow for E810 ??
stevehnz
Using E180 cards with latest (git) DPDK.
Looking to set a filter with an action that matches all packets and uncertain how to do this.
It appears that the L2 Ethernet filter (as an example) "requires" a match on (one of) type/smac/dmac.  There doesn't seem to be a catch-all/default path with an action associated with it.
testpmd> flow create 0 ingress pattern eth / ipv4 tos is 1 / end actions queue index 1 / end
Flow rule #0 created
testpmd> flow create 0 ingress pattern eth / end actions drop / end
ice_flow_create(): Failed to create flow
 Many Thanks...
Crisselle_Intel
Hello stevehnz,
Since this question involves DPDK, we highly suggest checking this with our Intel Premier Support. See the following for access to Intel Premier Support. Click the "Access and Log In" to contact the DPDK support " https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Let us know if you have questions and clarifications.
Should there be no response, I’ll make sure to reach out after 3 business days.
Crisselle C
Intel® Customer Support
stevehnz
Thanks Crisselle, we don't have access to that and have contacted our main intel contact to find out more.
We get his error:
You don't have Access to IPS.
Please contact the FAE to get access.
If you are an Employee and want Customer Role, Please raise request in AGS
New Customers
  • Work with your Intel representative to be granted access.
For customer support, submit any Intel® Premier Support Issues by clicking the Report a Site Issue link in the Help section of the left panel of the interface.
AlfredoS_Intel
Hi Stevehnz,
Thank you for providing that information.
We will continue checking this and the information that provided is invaluable to us.
Please allow us some time to check on this. We hope for your understanding regarding this
We will get back to you no later than 3 business days from now.
Alfred S
Crisselle_Intel
Hello stevehnz,
Good day!
You mentioned 'have contacted our main intel contact to find out more.' With this, please give us an update once you've contacted them and share their feedback with us. Once we heard from you, we will check this internally.
Should there be no response, I will make a follow up after 3 business days.
Crisselle C
stevehnz
We have IPS access now and raised the question there.
Steve
Crisselle_Intel
Hello Steve,
Appreciate your reply.
Good to hear that you now have access to IPS, they are in best position to address your query.
Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer being monitored.
May you have an amazing weekend!
Crisselle C
