Ethernet Products
5770 Discussions
Determine transceiver module serial number from i40e (XL710) pf driver ?
YBask
How can the transceiver module's serial number be extracted in the pf driver ? Also is it possible to extract the transceiver serial number in the VF driver ?
Hi Yogaraj.Baskaravel,
Thank you for posting at Wired Communities. Unfortunately our driver do not have the capability to extract the serial number. Hope this clarified.
regards,
sharon
regards,
sharon
Just want to check if any further assistance or clarification needed?
regards,
sharon
YBask
Hi Sharon!
Thanks for the answer. Is there any plans to add that support in the near future ?
If not I am going to start writing a patch to add that support at least for SFP+. Can I get any assistance if I run into some issues when writing the patch ?
Thanks in advace,
Yogaraj
Hi Yogaraj,
Thank you for the reply. I will need to further check. Thanks.
regards,
sharon
Hi Yogaraj,
Further checking, please post your request in https://sourceforge.net/p/e1000/feature-requests/ https://sourceforge.net/p/e1000/feature-requests/ the sourceforge support can further assist from there. Thanks.
Hope this helps.
regards,
sharon
