Ethernet Products
5736 Discussions
Difference between E10G42BTDA and E10G42BFSR
klin46
Hi! I would like to know what are the difference between
the first one has a cable type:
SFP+ direct attached
twin axial cabling up to 10 m
and the second one:
MMF 62.5/50 μm
up to 300 m
I need to use the E10GSFPSR. Wich one of the previously mentioned network adapter is compatible with this sfp+ module?
And what about your E10G41BFSR?
Thank you.
Kaiyu
Mark_H_Intel
Hi Kaiyu,
http://www.intel.com/support/network/adapter/pro100/sb/CS-030612.htm http://www.intel.com/support/network/adapter/pro100/sb/CS-030612.htm has the answers you are looking for.
are the same except that one ships without optical modules (BTDA) and one has SR optical modules installed (BFSR). Both adapters can use E10GSFPSR.
E10G41BFSR has one port and E10G42BFSR has two ports. Both adapters can use E10GSFPSR.
I hope this helps.
Mark H
