I am looking to see the difference between the to devices. If you have a datasheet that describes the different parts from the same family, it would be greatly appreciated.
Hello @Gary8,
This is the general difference between Intel® Ethernet Controller X710-AT2 and Intel® Ethernet Network Adapter X710-T2L:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=189463,189534
Depending if you own a Dual / quad-port energy-efficient adapters for NBASE-T and 10GBASE-T networks or Intel® Ethernet Network Adapter X710-T2L/T4L:
Its controller will be Intel® Ethernet Controller X710-AT2 (Dual Port) / Intel® Ethernet Controller X710-TM4 (Quad Port).
You may refer to the Product Brief
Can you confirm if you have an account to Resource & Design Center? If yes, you may refer to link below for X710-AT2 or X710-T2L datasheet,
- For X710-AT2 datasheet,
- For X710-T2L datasheet,
https://cdrdv2.intel.com/v1/dl/getContent/619593/view?wapkw=X710-T2L%20datasheet
In case you don't have access, the RDC Account Support form is the channel to process your account update process or report any problems with the provided sites. You should fill out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
Thank you.
BY_Intel
Intel Customer Support
Hello @Gary8,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know.
Thank you.
BY_Intel
Hello @Gary8,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
