Ethernet Products
5394 Discussions
Disabling VLAN stripping on 82599 card when using SR-IOV
SNico3
I have 2 VMs and each has a VF assigned from the same card.
The VMs have installed some apps that communicate with tagged(8021Q) traffic between them. Eg: Client App - VM - PCI - VM - Server App
The issue is that although tagged traffic exists one VM, it will arrive at the other stripped of the tag.
Is there a way to disable this behaviour? Even by recompiling the driver?
Silviu
modinfo ixgbe | grep ^version
version: 4.3.13
st4
New Contributor III
Hi silviu123,
Let me look into this.
rgds,
wb
st4
New Contributor III
SNico3
Hi wb,
I know it's enabled by default, but i need to disable it.
Is there a way to do this?
Silviu
st4
New Contributor III
Hi silviu123,
I have to further check how this can be done.
rgds,
wb
