Ethernet Products
5821 Discussions
Document request for Fisher Flat External Product Specification(EPS)
ChunHuat_Y_Intel
Customer looking for available of EPS for Fisher Flat adapter card model XL710-QDA2.
Hi gar\yeohchux,
For the available product documents related to XL710-QDA2, please check the link below:
http://ark.intel.com/products/83967/Intel-Ethernet-Converged-Network-Adapter-XL710-QDA2
Vince
ChunHuat_Y_Intel
Hi Vince,
This is no helpful for me and you point out the link not for OCP.
Fisher Flat network adapter card support 10GbE/40GbE based on single or dual port SKU.
My question is customer looking for Fisher Flat External Product Specification(EPS) document, does this document available? When document will be release it?
Patrick
Hi Patrick, sharing another link below:
http://ark.intel.com/products/85479/Intel-Ethernet-Server-Adapter-X520-DA2-for-Open-Compute-Project
Please share the specific information your customer is looking for in the EPS so we can check this internally.
Vince
Hi Patrick, we'd like to check if you still need assistance regarding this topic.
Vince
ChunHuat_Y_Intel
Hi Vince,
Customer would like to know power consumption specification, this will covering for current consumption and DC power consumption.
Patrick
Hi Patrick, let me check on the power consumption specification of X520-DA2 for Open Compute Project and update this thread as soon as possible.
regards,
Vince
Hi Patrick, you may obtain the needed document from the link below: before sharing it to your customer kindly have them complete the NDA first.
https://irefservices.intel.com/ContentTransferService.svc/0902007c80055ea9?ApiKey=7c30ff7e-1de8-4238-93e5-8b791af5d362
regards,
Vince
ChunHuat_Y_Intel
Hi Vince,
Yes, this is NDA customer.
As you said power consumption specification of X520-DA for OCP are same for XL710-QDA OCP platform?
If power consumption is confirm, then I will inform customer to follow accordingly, thanks.
Patrick
Hi Patrick, the XL710 supports 40Gbps connection and the minimum and maximum power consumption is higher by ,2-.3 watts.
regards,
Vince
Vince
ChunHuat_Y_Intel
Hi Vince,
Just to double confirm on XL710 40Gbps power consumption.
As you said as below;
Min > 0.3W
Max > 2W
Patrick
Hi Patrick, Comparing X520 and XL710 OCP, XL710 consume more power with approximate min > 0.3W and Max > 2W, I'd recommend to check the https://irefservices.intel.com for the detailed value as these are NDA information.
regards,
Vince
ChunHuat_Y_Intel
Hi Vince,
I do not have further questions would like to ask anymore since release of Fisher Flat EPS still not available.
If you know Fisher Flat EPS where to get will be great, if not please close this case, thanks for your help.
Patrick
