I started working on Intel 82599 and as a initial step trying to test VLAN configuration on VFs.
I see it only allowing to configure one VLAN per VF. I used following command to configure VLAN 25 for VF0 of port1 (eth2) on my 82599 device.
# ip link set eth2 vf 0 vlan 25
When I try to add one more VLAN 28 using "ip link set rename19 vf 0 vlan 28", I observed it overridden previous VLAN configuration and now the VF is part of VLAN 28 only.
Could you please suggest if we can configure multiple VLANs on a VF; if so, please suggest the necessary configuration.
Thanks in advance.
Note: As it is just experiment, I am trying to use VFs on host itself. I am not assigning these VFs to VMs.
VSR
Hi VSR, based on the previous post related to VLANs on VF, it's only one VLAN per VF. sharing the link below:
regards,
Vince
