We wanted to know if both the ports within Intel E810-CQDA2 NIC support duplex traffic ?
If yes, what is the maximum bandwidth supported by each of the ports in duplex mode ?
Prasad
Hello PrasadKulkarni,
We will move your question to the correct sub-forum, and the team in charge will get back to you soon.
Jean O.
Can you share more information regarding your intended configuration or why do you need to know this information? This is just for our record purposes.
Awaiting to your reply.
Should there be no reply, we will follow up after 3 business days.
Crisselle C.
Intel® Customer Support
Hi Crisselle,
We would like to transfer two different types of traffic within each of the ports and would want each of the traffic to work independently without impacting each other's bandwidth.
Also, each of the ports should allow full utilization of the link simultaneously without impacting each other.
Please let us know.
PrasadKulkarni
Thank you for the swift response.
Please allow us to further check on this request. We will give you an update as soon as possible but no later than 3 business days.
Hoping for your kind patience.
Crisselle C.
Intel Customer Support
Thank you for the patience on this matter.
Please visit the link below and go to page 89 3.2 Ethernet Interconnect and let us know if you have questions or clarifications.
Intel® Ethernet Controller E810 Datasheet
https://cdrdv2.intel.com/v1/dl/getContent/613875
Please also provide the PBA of the adapter. You may refer to the link below on where to find the PBA number. Providing photos of the adapter focusing on the markings (white sticker) found on the physical card will be highly appreciated for us to double check on it. The PBA consists 6-3 digit number located at the last part of the serial number. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
How are you doing?
This is just a follow up to check if you read our update. If yes, please confirm and let us know if you have additional questions or clarifications.
Crisselle C.
Good day!
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you for choosing Intel and stay safe!
Crisselle C.
