Ethernet Products
5720 Discussions
Does x710 support l2vpn-xconn-point2point in HW
qrun
I am looking for a NIC card with SFP+ adapter that allows two ports to be connected transparently.
It should not be a switch, as all frames should be transported transparently.
This should be done in hardware and not burden the PC's CPU.
At Cisco, this is the l2vpn xconn point-to-point service:
https://www.cisco.com/c/de_de/support/docs/routers/asr-9000-series-aggregation-services-routers/116453-technote-ios-xr-l2vpn-00.html
Furthermore, I would like to be able to capture the Rx/Tx stream as mirroring, filter it and reduce the frame
Like the Cisco function
mirror first 100
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r7-5/interfaces/configuration/guide/b-interfaces-hardware-component-cg-asr9000-75x/b-interfaces-hardware-component-cg-asr9000-71x_chapter_01001.html
Can the x710 offer these functions?
Or how do I achieve this with other functions in Hw?
Poojitha
Hi qrun,
Greetings for the day!
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Poojitha
Poojitha
Hi qrun,
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
We appreciate your understanding!
Poojitha
Poojitha
Hi qrun,
Poojitha
