Ethernet Products
4875 Discussions
Driver Installing for Intel PRO/1000 PT Quad-Port on Server 2016
I have a problem to install the current driver for my Intel Pro/1000 PT Quad PCIe Card on Server 2016 with Intel S5000PSL Mainboard..
When I use this Driver https://downloadcenter.intel.com/de/download/26092/Ethernet-Intel-Netzwerk-Adapter-Treiber-f-r-WindowsServer-2016-?product=83418 https://downloadcenter.intel.com/de/download/26092/Ethernet-Intel-Netzwerk-Adapter-Treiber-f-r-WindowsServer-2016-?product=83418 while the Installation Progress the System hangs up and froze. I have to make a hard reset.
When I use this Driver https://downloadcenter.intel.com/de/download/22283/Intel-Ethernet-Adapter-Verbindungen-CD?product=50497 Download Intel® Ethernet-Adapter Verbindungen CD while the Installation Progress a message Comes and say's, that no Intel Products have been found.
Where can I get the proper Driver?
Please help!
Thank you.
CARL_W_Intel
The Intel(r) PRO/1000 PT Quad Port Server adapter is based on the Intel 82751EB Ethernet controller. This controller, which launched in 2005, does not have a driver available for download from the Intel download center. The driver required to run this controller is included inbox in Windows Server 2016. All support for this controller in this OS is through Microsoft directly.
You can get more details here:
Thank you for your reply. The Problem with the included inbox Driver from Windows Server 2016 is, I get only 64 Mb/s filetransfer speed. I think it is the driver, which causes this low Speed. With other PC's I have 95 - 110 Mb/s transfer Speed. What can I do?
Hi FlexM3,
You need to contact Microsoft directly as this is inbox driver from Microsoft. Thank you.
Rgds,
wb
Hi FlexM3,
You are welcome.
wb
