Ethernet Products
Driver Vlan
ANetr1
Доброе время суток.
У меня есть несколько сетевых адаптеров
Intel(R) Ethernet Connection I219-V
Intel(R) Gigabit CT Desktop Adapte
Intel(R) Pro/1000 GT Desktop Adapte
Пробовал искать драйвера с поддержкой vlan на сайте результат нулевой.
Подскажите где достать нормальный драйвер с поддержкой Vlan
Спасибо
Daniel_D_Intel1
Hello ANetr1, Thank you for posting in Intel Ethernet Communities. What is the motherboard the I219-V is integrated with? Please let us know which operating system you are using? If this is for Windows 10, please let us know which build you need drives for, as the procedure for setting VLANs has changed in Windows 10 1809. Let us know if you have any other questions. We have used the "translate" tool in Intel Forums to translate your post to English. Note that we do not guarantee 100% translation accuracy. Best regards, Daniel D Intel Customer support Under contract to Intel Corporation
ANetr1
Hi, u ansver me only for 1 ethernet Adapte, but i ask u for 3 ethernet Adapte.
What is the motherboard the I219-V is integrated with? - yes
yes i have windows 10 Pro my build is 1809
drivers dont work
Daniel_D_Intel1
Hello ANetr1, Thank you for the reply. Are the Gigabit CT Desktop Adapter and Pro/1000 GT Desktop Adapter using Windows 10 1809 as well? If the adapters are installed on different systems please inform us of the operating systems. For Windows 10 1809 VLAN creation has changed from device manager in other Windows versions to PowerShell. This driver will provide support for the I219-V, but the Gigabit CT Desktop Adapter and Pro/1000 GT Desktop Adapter are not fully supported in Windows 10 and will use drivers from Microsoft: https://downloadcenter.intel.com/ru/download/25016/Ethernet-Intel-Network-Adapter-Driver-for-Windows-10?product=82186 See supported adapters here: https://www.intel.ru/content/www/ru/ru/support/articles/000020905/network-and-i-o/ethernet-products.html?_ga=2.190116523.123427942.1548836021-753214976.1529050232&elq_cid=1869446&erpm_id=6389079 For setting VLANs in PowerShell see the following: https://www.intel.ru/content/www/ru/ru/support/articles/000023545/network-and-i-o.html?_ga=2.132406411.463365546.1548835800-753214976.1529050232&elq_cid=1869446&erpm_id=6389079 Best regards, Daniel D Intel Customer support Under contract to Intel Corporation
ANetr1
ANetr1
i do some comand on PowerShell but have some question.
Get-IntelNetAdapter - i see my ethernet adapter next part i do this Add-IntelNetVLAN and after this comand i see ParentName[0] - Whot i Need writen Here ?
ANetr1
All Done, can closed this Team
Daniel_D_Intel1
Hello ANetr1, Thank you for the reply. Glad you were able to resolve this. Let us know if you have any other questions. Best regards, Daniel D Intel Customer support Under contract to Intel Corporation
