Does E10GSFPLR, when used with Intel x710 quad-port 10g sfp+ nic, auto negotiate to 1G.
- « Previous
- 1
- 2
- Next »
Yes. SFP-GE-LX-SM1310 is a Huawei SFP and Huawei confims that it supports 1000Base-LX (https://forum.huawei.com/enterprise/en/huawei-quidway-s5328c-1g-single-mode-sfp/thread/654997-861#pid3434503). That means if we use SFP-GE-LX-SM1310 in switch side and E10GSFPLR in intel adapter, it should work ?
Hi Indikaw,
We deeply appreciate that you provided more information regarding the Huawei SFP that you are inquiring about.
Based on what you said, as long as an Intel SFP is connected to our ethernet adapter then by theory your setup should work. It just that we have never tested this configuration before. It would be best, for you to be sure, to check with Huawei if the setup will work.
We hope for your understanding regarding this.
We will do a courtesy check with you after 3 business days to see if you have already confirmed your setup with Huawei.
Alfred S
Intel® Customer Support
Hi Indikaw,
We are just following up.
It looks like you need more time to carry out the recommendations that we have provided.
We will follow up again after 3 business days. Should we not hear from you, our system may automatically close the thread.
Alfred S
Intel Customer Support
I still need time to follow up with Huawei...
Hi Indikaw,
Thank you for your response.
No problem. You can have all the additional time that you need.
We will just do a routine check with you after 3 business days to check if you need more time.
Alfred S
Hi Indikaw,
It looks like you need more time to provide the information that we asked.
Alfred S
Hi Indikaw,
Alfred S
Dear Alfred,
I opened a thread with Huawei and they assume it should work with a Huawei SFP on Huawei switch.
Indika.
Hi Indikaw,
Thank you for your update.
It is a great joy to know that Huawei also confirms although through assumption that the setup should work.
Do you have any other questions or concerns?
Looking forward to your reply. Should we not get your reply, we will check back with you after 3 business days.
Alfred S
Hi Alfred,
Thanks a lot for helping.
Indika.
Hi Indika,
Thank you for the quick response.
We will go ahead and close the thread.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
- « Previous
- 1
- 2
- Next »
