Does E10GSFPLR, when used with Intel x710 quad-port 10g sfp+ nic, auto negotiate to 1G.
Hi Indikaw,
Thank you for posting in our Intel® Ethernet Communities Page.
You have a very good question.
To better assist you, we need to get some logs from your system. It will tell us the different driver version and components installed on your system. Please download and run our Intel® System Support Utility from this page, https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-. After running it, you will be given an option to save the logs to a text file, please do so and attach the file on your reply.
We would also like to know the speed profile that you set for each port of the card and how many of the available ports are you planning to use?
We look forward to hearing from you. If we do not get your reply, we will follow up after 3 business days.
Alfred S
Intel® Customer Support
Thanks for the reply. This is not an existing deployment but we are planning to deploy. We have a server with Intel X710 Quad port 10G (SFP+) nic and we need to connect 1G single mode fiber to it. When I checked the supported SFPs I found that E10GSFPLR is the single mode SFP that is supported. Now I need to know whether all 4 ports of Intel X710 card can work as 1GB single mode ports with E10GSFPLR tranceivers.
Indika.
- Tags:
- Hi
Hi Indikaw,
Thank you providing those information.
Please allow us some time to check on this.
We will get back to you no later than 3 business days from now.
Alfred S
Dear Alfred,
I am attaching the log file generated from the utility.
Indika.
Hi Indikaw,
Thank you again for providing those information.
Alfred S
Hi Indikaw,
Thank you for waiting for our update.
After doing initial reviews on the your concern, to provide you the most accurate answer to your question, please provide the following details:
1. Complete markings of the adapter. You may refer to this page if you need a guide on the markings that we are asking, https://www.intel.com/content/www/us/en/support/articles/000007060/network-and-i-o/ethernet-products...
2. May we know the brand and model of the switch that you are planning where the SFP will connect to?
We look forward to your reply. Should we not get your reply, we will follow up after three business days.
Alfred S
Hi Indikaw,
We are just following up.
It looks like you need more time to provide the information that we asked.
We will follow up again after 3 business days. Should we not hear from you, our system may automatically close the thread.
Alfred S
Dear Alfred,
I need little more time. Will get back to you.
Indika.
Hi Indikaw,
Thank you for your response.
No problem. You can have all the additional time that you need.
We will just do a routine check with you after 3 business days to check if you need more time.
Alfred S
Hi Indikaw,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers. We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
Dear Alfred,
Since this server is in production, I am waiting to get a downtime to remove the card and to get a picture of the markings. Really appreciate if you can give me couple of days more.
User confirmed that the upstream switch is Huawei.
Indika.
Also is there a way to get adapter markings without shutting down the server.
Indika.
Hi Indikaw,
No problem. You can have all the time that you needed. It was just a routine follow-up.
We will be waiting for your update. Should we not hear from you after 4 business days, we will be making a follow-up to give you ample time to get the markings of the card and to ask if you require more time
Alfred S
Dear Alfred,
Attached are the adapter markings.
Indika.
Hi Indikaw,
Please also provide the model of the Huawei switch if possible.
Alfred S
Hi Alfred,
Huawei Switch model is Huawei quidway S5328C.
Indika.
Hi Indikaw,
Thank you for providing that information.
We will continue checking this and the information that provided is invaluable to us.
Please allow us some time to check on this. We hope for your understanding regarding this
Alfred S
Hi Indikaw,
Thank you for patience in waiting for our response.
Here are our findings:
1. The E10GSFPLR supports dual speed - 1GbE (1000Base-LX) and 10GbE (10GBase-LR), as reference on page 2 of this product brief (https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-sfp-optics-brie...).
2. According to the feature matrix of X710 - page 10, it supports multi-speed (1/10 GbE) optical modules - matrix file located in https://www.intel.com/content/www/us/en/design/products-and-solutions/networking-and-io/ethernet-con... (customer communication section, content ID 332191)
3. When we checked the product details of your client’s switch (Huawei quidway S5328C), it listed few modules that supports SFP, SFP+ and we cannot find the part that it mentions to support 1000Base-LX
https://www.router-switch.com/pdf/ls-s5328c-ei-24s-datasheet.pdf
We highly recommended for you to contact the manufacturer of your switch to confirm if it supports the feature. It also depends where these Intel adapters are connected.
We look forward to your reply. Should we not get your reply, we will follow up after three to four business days to give you ample time to assess the answers that we have provided.
Alfred S
Hi Indikaw,
It looks like the adapter that you are inquiring about is a non-intel SFP. Are we correct? If yes, it would be best if you check with Huawei to confirm if they will auto negotiate 4 x 1 Gbps.
Alfred S
