Ethernet Products
5710 Discussions
E610-XT2 FW
MaxKao
Hi Guys:
               We are currently evaluating the E610-XAT2 solution and have proceeded with the purchase of the E610-XT2 reference board for OCP integration.
               However, we observed that in firmware version 1.01, the Port 2 Link/ACT LED would blink during activity. After updating the firmware to version 1.21 using the E610_NVMUpdatePackage_v1_21, the LED no longer blinks during activity.
               How should we proceed to ensure normal LED functionality? Are there any methods we can use to fix the LED issue?
Sreelakshmi1
Hi MaxKao,
Regarding the issue with LED activity, we recommend updating the NVM using Driver Pack 30.4, which includes NVM version 1.30. Kindly refer to the link below for further details.
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Sreelakshmi
Azhari_Intel
Hi MaxKao,
Good day to you.
We appreciate you reaching out to us regarding the reported issue. To assist you more effectively and provide an accurate solution, we kindly request the following details:
1. System/motherboard model used with the E610-XT2
2. BIOS/UEFI version currently running on the system
3. Network driver version installed on the host system (Windows/Linux, please specify OS and driver source).
You may also refer here for full list of OS compatibility:
https://www.intel.com/content/www/us/en/support/articles/000025890/ethernet-products.html
4. Does the LED remain completely off, or is it lit solid without blinking during traffic?
5. Are both ports showing the same behavior, or only Port 2?
6. For clarification, the Port 2 still able to establish connection after the update, correct?
Once we have this information, we will be able to guide you better and provide the appropriate support.
Azhari_Intel
MaxKao
Hi Azhari :
                  The reply is as follows:
     Ans: MB Gigabyte X570 Aorus Elite ( AMD X570 Chipset ) / Using form factor is OCP(requires a pcie to ocp adapter)
    Ans: BIOS Ver.F40g
    Ans: OS:Windows 11 / Driver: Intel website driver ixw in Release_30.3
     Ans: lit solid without blinking during traffic
    Ans: only Port 2
    Ans: Yes
Akshaya1
Hi MaxKao,
Thank you for sharing the details.
Kindly allow some time to review the information. We will get back to you with an update shortly.
Meanwhile, could you please share the image of the adapter with the labels clearly visible?
Akshaya
Intel Customer support Technician
MaxKao
Hi Akshaya :
                       pls see attach files.
Akshaya1
Hi MaxKao,
Kindly allow sometime to review it internally and will get back to you with an update shortly.
Akshaya
Sreelakshmi1
Hi MaxKao,
Sreelakshmi
Azhari_Intel
Hi MaxKao,
Good day to you.
Just wanted to follow up with you, kindly let us know if you have any further concerns.
Azhari_Intel
MaxKao
Hi Azhari :
                   I tried using NVM using Driver Pack 30.4, which includes NVM version 1.30, and confirmed that it can solve the LED issue.
Thanks !
Azhari_Intel
Hi MaxKao,
Thanks for your feedback.
Glad to hear that our earlier recommendation is able to resolve the issue you were facing.
If there are no further concerns, we will be closing this forum case from our end.
If you need any additional information or assistance, please feel free to reach out to us!
Azhari_Intel
