I bought 2 new Intel NICs - E810-2CQDA2 (WT Part: No.99AL14 & E810-XXVDA2 (WT part No. 978331), and install them in different PCs with OS Ubutu 22. In E810-2CQDA2 PC, I only see one port info in ifconfig & lspci,. Is this HW issue? (In E810-XXVDA2 PC, I can see 2 ports info in ifconfig & lspci). Can you recommand which firmware driver can install in this ubuntu PC? Thanks
E810-2CQDA2 PC:
svd@svd-iperf-3:~$ ifconfig
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.168.24 netmask 255.255.255.0 broadcast 192.168.168.255
ether a0:36:bc:bf:42:41 txqueuelen 1000 (Ethernet)
RX packets 23331 bytes 3003495 (3.0 MB)
RX errors 0 dropped 72 overruns 0 frame 0
TX packets 3950 bytes 375445 (375.4 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0x85e00000-85efffff
enp1s0np0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 40:a6:b7:c9:e6:68 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 618 bytes 48080 (48.0 KB)
TX packets 618 bytes 48080 (48.0 KB)
wlp0s20f3: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether f4:26:79:e4:ef:0d txqueuelen 1000 (Ethernet)
svd@svd-iperf-3:~$ ethtool -i enp1s0np0
driver: ice
version: 6.2.0-39-generic
firmware-version: 4.30 0x8001be17 1.3429.0
expansion-rom-version:
bus-info: 0000:01:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
svd@svd-iperf-3:~$ lspci
00:00.0 Host bridge: Intel Corporation Device a703 (rev 01)
00:01.0 PCI bridge: Intel Corporation Device a70d (rev 01)
00:02.0 VGA compatible controller: Intel Corporation Raptor Lake-S GT1 [UHD Graphics 770] (rev 04)
00:06.0 PCI bridge: Intel Corporation Device a74d (rev 01)
00:0a.0 Signal processing controller: Intel Corporation Device a77d (rev 01)
00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller Intel Corporation
00:14.0 USB controller: Intel Corporation Device 7a60 (rev 11)
00:14.2 RAM memory: Intel Corporation Device 7a27 (rev 11)
00:14.3 Network controller: Intel Corporation Device 7a70 (rev 11)
00:15.0 Serial bus controller: Intel Corporation Device 7a4c (rev 11)
00:15.1 Serial bus controller: Intel Corporation Device 7a4d (rev 11)
00:15.2 Serial bus controller: Intel Corporation Device 7a4e (rev 11)
00:16.0 Communication controller: Intel Corporation Device 7a68 (rev 11)
00:17.0 SATA controller: Intel Corporation Device 7a62 (rev 11)
00:1a.0 PCI bridge: Intel Corporation Device 7a48 (rev 11)
00:1b.0 PCI bridge: Intel Corporation Device 7a40 (rev 11)
00:1c.0 PCI bridge: Intel Corporation Device 7a38 (rev 11)
00:1c.2 PCI bridge: Intel Corporation Device 7a3a (rev 11)
00:1d.0 PCI bridge: Intel Corporation Device 7a30 (rev 11)
00:1f.0 ISA bridge: Intel Corporation Device 7a04 (rev 11)
00:1f.3 Audio device: Intel Corporation Device 7a50 (rev 11)
00:1f.4 SMBus: Intel Corporation Device 7a23 (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Device 7a24 (rev 11)
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller E810-C for QSFP (rev 02) --> Only see one port info
02:00.0 Non-Volatile memory controller: Micron/Crucial Technology P5 Plus NVMe PCIe SSD
06:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 06)
svd@svd-iperf-3:~$
E810-XXVDA2 PC:
svd@svd-iperf-1:~$ ifconfig
inet 192.168.168.26 netmask 255.255.255.0 broadcast 192.168.168.255
ether 58:11:22:c5:1e:29 txqueuelen 1000 (Ethernet)
RX packets 301218 bytes 414090034 (414.0 MB)
RX errors 0 dropped 2286 overruns 0 frame 0
TX packets 130635 bytes 8742877 (8.7 MB)
enp6s0f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.222 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::5813:a3f9:64fa:4a6f prefixlen 64 scopeid 0x20<link>
ether 50:7c:6f:62:fd:f2 txqueuelen 1000 (Ethernet)
RX packets 635 bytes 64778 (64.7 KB)
RX errors 0 dropped 42 overruns 0 frame 0
TX packets 685 bytes 107543 (107.5 KB)
enp6s0f1np1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 50:7c:6f:62:fd:f3 txqueuelen 1000 (Ethernet)
RX packets 1625 bytes 134233 (134.2 KB)
TX packets 1625 bytes 134233 (134.2 KB)
svd@svd-iperf-1:~$ enp6s0f0np0
enp6s0f0np0: command not found
svd@svd-iperf-1:~$ ethtool -i enp6s0f0np0
driver: ice
firmware-version: 4.30 0x8001b891 1.3415.0
bus-info: 0000:06:00.0
supports-test: yes
svd@svd-iperf-1:~$ lspci
00:1c.4 PCI bridge: Intel Corporation Device 7a3c (rev 11)
01:00.0 Non-Volatile memory controller: Micron/Crucial Technology P5 Plus NVMe PCIe SSD
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
06:00.0 Ethernet controller: Intel Corporation Ethernet Controller E810-XXV for SFP (rev 02)--> Port 1
06:00.1 Ethernet controller: Intel Corporation Ethernet Controller E810-XXV for SFP (rev 02)---> Port 2
BR,
Leo
