Ethernet Products
5737 Discussions
[E810-C] How can I change MaxReadReq and ECRCGenEn , ECRCChkEn
YSLEE
My 100Gbit ethernet controller E810-C shows below using "lspci -vv"
MaxPayload 512 bytes, MaxReadReq 512 bytes
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
I want to change MaxReadReq to 4096
and I also want to enable ECRCGenEn, ECRCChkEn
How can I do it?
Sreelakshmi1
Hi YSLEE,
Greetings!
To assist you further with the issue, could you please provide the following details?
  • System information you are currently using.
  • Complete model name of the Ethernet card.
Sreelakshmi
Sreelakshmi1
Hi YSLEE,
Greetings!
We are following up to find out if you were able to find the information we requested earlier. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Sreelakshmi
YSLEE
I've solved this problem.
I can change these values using "setpci" command in my Linux system and also I can find the register on Intel E810-C datasheet.
Thanks!
Sazirah
Hi YSLEE,
Thank you for confirming this. We are glad that the issue has been resolved. Since the issue has resolved, we will proceed to close this case at our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Thank you for using Intel products and services.
Sazzy_Intel
