Ethernet Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4741 Discussions
E810-CQDA2 performance on dual ports at the same time
LIVING
It is not clear if the whole card(E810-CQDA2) can only generate 100G at the same time or can it generate 200G? I run a test with both ports connected b2b with a dac cable and run a unidirectional test at the same time , I get appox 50Gbps per port actually
sk_plc2
Which motherboard/CPU are you using? The PCIe Gen4 x16 interface of the card is capable of handling more then 200Gbit/s, but many factors limit the achievable bandwidth:
  • PCIe link
  • CPU load
Last but not least, the E810 chip could limit the throughput, but I doubt it.
Mike_Intel
Hello LIVING,
For us to further check the issue, please provide the following details.
  1. Are you using a PCIe E810 or embedded/onboard network card?
  2. What is the brand and model of your board/system?
  3. Can you provide a screenshot of the issue?
  4. Please provide the link of your network card driver.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Mike_Intel
Hello LIVING,
I hope you're having a wonderful day. I am just sending a follow up on the information that we requested for us to further assist you.
We will wait for your reply.
Michael L.
Mike_Intel
Hello LIVING,
I hope this message finds you well. I am just sending another follow up on the information that I requested. Since we have not heard back from you, I need to close this inquiry.
Thank you and stay safe.
Michael L.
