Hi Team,
we are using intel e810 mac in our custom board , do we have any idea about below queries.
Required Ethernet Configuration : 2 x25G
1. Can we flash the firmware(spi flash) of e810 externally using external spi flasher like dediprogrammer ?We are planning to use sf100 flasher ?
2. If answer to question 1 is yes , which is the binary we need to use ,can you share the link or the file for the same ? Which is the binary we need to use for below configuration ?
3. Is there any offset on flashing the spi flash or we can start from address 0x00 ?
4. As we are using custom board , we have our own methods to flash the spi , so will flashing the spi alone will boots up the system with full functionalty ? If no can you tell us what is the steps we need to do ?
Note - We have validated the functionalty of e810 evk with our arm64 based processer Ampere ultra max.
Adithyan
Hello @adithyan ,
We found that there are a few similar posts created by you.
However, you may continue to update/follow up on this below link:
https://community.intel.com/t5/Ethernet-Products/E810-EYE810XXVAM2-Initial-Flashing-Procedure/m-p/1588300#M37282
We will proceed to close this thread as a duplicate.
Fikri_Intel
