Hi there!
I'm faced with unexpected behavior when try to send LACP packet to port under testpmd control. Here is what I did :
- Bind port to igb_uio driver:sudo usertools/dpdk-devbind.py --unbind 0000:8b:00.7sudo usertools/dpdk-devbind.py --bind=igb_uio 0000:8b:00.7
- Run testpmd:
sudo ./dpdk-testpmd --log-level=debug -l 2,3 -- -i - Start forwarding:
testpmd> start tx_firs - Send from another server LACP packet to port under testpmd control
- Show xstats and it's all good for now:
testpmd> show port xstats 0rx_good_packets: 4rx_unknown_protocol_packets: 0 - reset port 0testpmd> stoptestpmd> port stop 0testpmd> port reset 0testpmd> port start all
- Show xstats and see that `rx_unknown_protocol_packets` encountered:
rx_good_packets: 0rx_unknown_protocol_packets: 4
Configuration: E810 NIC, firmware-version: 3.10, DPDK version: 21.11.0.
I don't know if this behavior is normal, but I would like the LACP traffic not to be dropped by the card. Thanks!
Hi Alex107,
Thank you for reaching out to the Intel support. We acknowledge receipt of your concern and want to assure you that assisting you is our top priority. To effectively troubleshoot the issue you're facing, we require some additional information from your end.
Could you kindly provide the following details?
1. System/board details:
2. Complete ethernet card details:
Your prompt response with this information will greatly assist us in diagnosing and resolving the issue as quickly as possible.
We look forward to hearing from you soon.
Simon
