Ethernet Products
5718 Discussions
E810-XXV PCIe NIC RoCE irdma Driver Load Issue
latency_hunter
Hello I am using a E810-XXV on Debian 12 standard 6.1.0-26-amd64 Linux kernel. I would like to test some RoCE functionality, and wanted to update to the latest drivers to see if it would solve any of the issues I am seeing.
I upgraded ice to 1.15.5 and irdma to 1.15.15. however when loading irdma:
sudo modprobe irdma roce_ena=1
I get the error (in dmesg) :
[ 4089.556646] irdma driver version: 1.15.15
[ 4089.556996] version mismatch:
[ 4089.557065] expected major ver 10, caller specified major ver 32776
[ 4089.557170] expected minor ver 4, caller specified minor ver 2551
[ 4089.557263] irdma: probe of ice.roce.0 failed with error -22
[ 4089.557718] version mismatch:
[ 4089.557806] expected major ver 10, caller specified major ver 32776
[ 4089.557899] expected minor ver 4, caller specified minor ver 3042
[ 4089.557992] irdma: probe of ice.roce.1 failed with error -22
Should I not be using ice 1.15.5 with my irdma version or is this compatibility issue somewhere else?
latency_hunter
I sorted this out. Turns out while the new IRDMA driver was loading at boot the old ICE driver was still loading.
1. Check the driver version with `ethtool -i <DEV>`
2. Remove old driver : `sudo rmmod irdma ice`
3. Restart drivers : `sudo modprobe ice ; sudo modprobe irdma roce_ena=1`
There is something wrong with my ice install (as the new version does not load at boot), but I will sort that out later.
latency_hunter
