Ethernet Products
E810-xxvam2
Greif
I have a packet with a tagged VLAN. I have tried different setups but am still missing something, since I am not receiving the packet that I sent. I do not want the tag to be stripped from the packet. In essence I just want the packet to pass thru without any conditioning being done.
What should the registers be set to. I have tried changing the “showIV and L2TSel and many other registers. Any idea’s ?
Greif
IntelSupport
Community Manager
Hi Greif,
Kindly check below links if it helps on your issue:
https://www.intel.com/content/www/us/en/support/articles/000005498/ethernet-products.html
 https://www.intel.com/content/www/us/en/support/articles/000005677/ethernet-products.html
Please provide us more details if needed as well as any screenshot.
Please let us know if you have any questions.
Hayat
Intel Customer Support
Greif
Hayat, thanks for the response
checking on the promiscuous mode that was mentioned.
Can we go a little deeper to the chip level. Dealing with a tagged VLAN on the receive packet.
The E810 Datasheet section 7.12.3.3 states that the tag extraction rules are controlled by the following:
 VSI_TSR.STRIPTAG, VSI_TSR.SHOWTAG, and VSI_TSR.SHOWPRIONLY bit fields.
Within Table 7-290 Tag Extraction Example, the document talks about “SHOWIV and L2TSEL”:
We, have SHOWIV and L2TSEL set to a 1, 0 respectfully.  Which selects Inner VLAN on L2TAG1.
However, I believe this only pertains to different cases assuming the first tag is an STag and the second tag is a VLAN.
We don’t have a Stag only a typical 802.1 (8100) vlan tag.
If the VSI_TSR.STRIPTAG, VSI_TSR.SHOWTAG, and VSI_TSR.SHOWPRIONLY bit fields control the extraction rules how do you set this for “DO nothing” leave the packet as is.
Greif
IntelSupport
Community Manager
Hi Greif,
Since your questions are out of our support scope.
Kindly post your questions on the link below and our dedicated team will get back to you shortly:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Thus, we will proceed to close the case. Once the case is closed it will no longer be monitored by Intel. Kindly open a new case if you have further questions.
Thank you.
Hayat
