Ethernet Products
5823 Discussions
ERROR Installing Network DRIVER Windows 10 _Advanced_VLANS
PRudi
Hello!
I Need your help please.
I have a Problem to configure advanced Network Settings.
How you can see i Always get an error (ERROR FILE) that i have a wrong DRIVER (in PowerShell) But if i like to update my Driver (see File DRIVER) than Windows says i have the best Drivers?
What should i do i Need it because i Need 2 VLANS on 1 Networkcard....please!
Thank you very much to all.
LeonWaksman
  1. You asked your question in NUC forum.
  2. In order to give you some advice, please describe what is your NUC model and Windows 10 version?
Leon
PRudi
​sry wrong catagory i have a normal PC sry ….can i put it in a other catogery or should i delte it ….sry for that guys…..:( please can someone help me for this Problem....thx for all
Caguicla_Intel
Hello PRudi,
Kindly share the following details for us to check on your query.
1.) System Support Utility log of your system. This will allow us to check your Adapter details and configuration. This would also help us identify if you are using an OEM or retail version of Intel Ethernet Adapter. Kindly refer to the steps below.
a- https://downloadcenter.intel.com/product/91600/Intel-System-Support-Utility
b- Open SSU.exe
c- Mark the box "Everything" and then click "Scan".
d- When finished scanning, click "Next".
e- Click on "Save" and attach the file to a post.
2.) Share the link where you downloaded the driver.
3.) Are you using 1809 version on your Windows 10?
We look forward hearing from you.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
PRudi
Hello CrisseleC!
Thank you for you answer!
I have Windows 10 Version 1903.
I have made the scan and saved it. (ws-bennik)
I downloaded the driver from Intel Mainpage. I really dont know whats the problem because if i like to reinstall it windows says i have the best drivers.
THANK YOU SO MUCH!
Patrick R.
Caguicla_Intel
Hello Patrick,
Thank you for providing the requested details.
Please be informed that there is no Intel Windows 10 driver for the Intel® 82579LM Gigabit Ethernet, the available Windows driver is the inbox (built-in driver) from Microsoft*. For Inbox support, it doesn't include Intel® PROSet for Windows* Device Manager and Intel® Advanced Network Services (Intel® ANS) driver for teaming and VLANS.
Please visit this link for Windows® 10 Support for Intel® Ethernet Adapters
https://www.intel.com/content/www/us/en/support/articles/000020905/network-and-i-o/ethernet-products.html
Let us know if you have additional questions and clarifications on this matter.
We look forward to hear from you.
Crisselle C
PRudi
Thank you CrisselleC!
So it isnt possible to add VLAN ?
I thought i can do it maybe with Powershell but it doesnt work .....so there is no workaround?
Thank you so much for your fast answer.
Best regards
Patrick R.
Caguicla_Intel
Hello Patrick,
Thank you for the prompt reply.
Please allow us to check on this further if there are any workaround. We will give you an update within 1-3 business days.
Hoping for your patience.
Crisselle C
PRudi
Hello CrisselleC_Intel!
Thank you so much. I will wait =)
I tried so many things but i think it will be hard to get a workaround.
Patrick R.
Caguicla_Intel
Hello Patrick,
Thank you for the patience on this matter.
After further checking, the last full support for 82579LM was RS4 (1803). We would suggest to go with adapter that has full support like the I210-T1.
You may visit this link for the product specifications of Intel® Ethernet Server Adapter I210-T1
https://ark.intel.com/content/www/us/en/ark/products/68668/intel-ethernet-server-adapter-i210-t1.html
Looking forward to hear from you.
Crisselle C
Caguicla_Intel
Hello Patrick,
We'd like to check if you have additional questions and clarifications on this matter. If you do, please let us know and we will be glad to be of help.
Awaiting to your reply.
Crisselle C
Caguicla_Intel
Hello Patrick,
Good day!
Please be informed that we will now close this inquiry since we haven't received any reply from our previous follow up. Should you have any other concern or further assistance needed in the future, please do not hesitate to post a new question.
Crisselle C
