Ethernet Products
4527 Discussions
ESXi 6 X710 Port Speed configuration
SMerk
I have several X710-DA2 cards in the ESXi Server. When I leave the port speed of that cars as it is everything works fine. When I try to change the speed to 10GBit I get an error message: "Forcing 1000Mbps or faster may not be supported on this network device, please use auto-negotiation instead"
After that all X710 ports go offline and I cannot be activated again. The link is down and the vmnic has a red cross.
The only way to get it working again is to Restore the ESXi configuration backup that was made before the change.
Driver/Firmware is the following:
[root@localhost:~] ethtool -i vmnic4
driver: i40e
version: 1.2.48
firmware-version: f4.22.27454 a1.2 n4.25 e143f
bus-info: 0000:0d:00.0
Any ideas?
Steffen
st4
New Contributor III
Hi Steffen_ST,
Thank you for the post. What is the switch model the X710-DA2 connets to?
Let me further check on this also.
rgds,
wb
SMerk
Hi wb,
the X710-DA2 connects direct to another X710-DA2. There is no switch between.
Steffen
SMerk
Hi wb,
Steffen
st4
New Contributor III
Hi Steffen_ST,
rgds,
wb
SMerk
Hi wb,
Steffen
SMerk
Hi wb,
Steffen
