Ethernet Products
5716 Discussions
EXPI9301CTBLK Network Adapter won't connect to network
I recently bought this NIC and installed it in my WinXP Pro desktop system.
I downloaded the PRO drivers from Intel and the OS sees the NIC with no problem.
However, I am continuously getting the following sequence of messages:
network disconnect
acquiring IP address
network disconnect
network disconnect
This does not stop.
I tried a different cable. I tried a different switch to connect to.
Any ideas on what might cause this?
Thanks!
Mike
Mark_H_Intel
Hi Mike,
Did you ever figure out a solution? What did you do?
If you are still looking for ideas, then here are a few things you can try:
  1. Completely uninstall the Intel Network Connections software. Then install the latest software from http://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=18717 http://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=18717.
  2. If you have another PCI Express slot, move the adapter to a different slot, especially if you are using one of the x16 slots usually used for video adapters.
  3. Make sure your computer BIOS is up to date. Sometimes PCIe slot issues get fixed by BIOS updates.
  4. Run the hardware diagnostics from the adapter properties in Windows Device Manager. If the diagnostics pass, the adapter is probably good. See the picture for how to find the hardware diagnostics.
I hope this helps.
Mark H
