Ethernet Products
5611 Discussions
EXPI9400PF - or any fiber card.. - cabling question
SBlitz
New Contributor II
I'm using Linux with this card. I want to use 50micrometer cable , instead of 62.5 one. Should I touch / change anything in driver parameter ? This card is compatible with both, but is it automatic ?
Saar
Mark_H_Intel
Hi Saar,
By now you probably found your answer elsewhere, but I will answer anyway in case someone else reads this thread.
You do not have to configure anything on the fiber adapters related to using different diameter cables. This is true for any OS and on any of our fiber adapters.
I hope this helps.
Mark H
