Ethernet Products
5821 Discussions
Enable Wake on Magic Packet Intel 82579lm NIC
MThac
I am looking to deploy a wake on lan solution to one of the sites that I manage. I have found a VBscript that takes care of most adapters, but not Intel 82579lm adapters.
I followed some very helpful information from this thread: /thread/19132 https://communities.intel.com/thread/19132 and changed the commands to reflect wake on magic packet. Unfortunately I keep getting a failure message. The thread that I was using for reference was for a different model Intel NIC, but I hopped that it would work.
Does anyone have any guidance in enabling wake on magic packet via command line and prosetcl.exe for Intel 82579lm adapters?
Any help would be much appreciated.
MThac
Ok, Solved it. The same command line syntax works for the 82579lm adapters. Its just a fragile driver if you have both the GUI open and make changes via the commandline.
IntMax76
Hi, could U explane me the right procedure?
