Ethernet Products
5821 Discussions
Error 1.0.107001.24404 IPFSRV
Grillobirillo
Good morning everyone,
for some time (never had this problem before) when starting the win11 system (ONLY at the first request) the connection to the disk x: on the Qnap TS 212P Nas is not available, all the applications that refer to this do not find the path, if I click on the connection again everything starts working again until the new restart.
Attached is what was detected and the list of related errors from the event log.
SFC scannow does not detect errors. If from the command prompt I try to access x: before clicking at least once on the connection the disk is not available (then everything works until cmd)
From cmd can I replicate what the system does when you click on a connection? (Explorer x: does not work, the first time then....)
PC: Lenovo 30FM000YIX - i5-12600K
Thanks for your attention.
DhannielM_Intel
Hi Grillobirillo,
To further assist you with this, I have some questions for clarification:
  1. Can you confirm to me that this is the device you are currently using, TS-212P?
  2. Are you having connection issue with this device?
  3. Lastly, are you connected to this device via cable or wirelessly?
Dhanniel M.
Grillobirillo
dear Dhanniel,
I can confirm that I regularly use the NAS TS-212
never had problems with the connection with the NAS,
the connection is via cable.
Repeat: only at the first request it does not work, then everything is ok!
mg
DhannielM_Intel
Hi Grillobirillo,
Thank you for this information. There are some follow up questions that I would like to ask:
  1. Since you mentioned that you are having connection via a cable, can you confirm if you are using a Type C Thunderbolt™ 4 cable?
  2. Have you tried contacting Lenovo and/or QNAP for this issue?
  3. Also is your system has a Thunderbolt™ 4 port?
Dhanniel M.
Grillobirillo
dear Dhanniel,
the cable I use is the classic RJ45 cat. VI
I have never contacted Levnovo or Qnap, because I think the problem arose after the Intel drivers update (Ethernet: Ver. 12.19.2.60)
My system does not have a Thunderbolt port -
A question: does the ESIF 1.0.70701.24404 error come from Intel drivers or something else?
Grazie
DhannielM_Intel
Hi Grillobirillo,
Thank you for posting in the community!
Based on the product that you have posted which is the Qnap TS-212P is not related to the Processor. Therefore, to ensure that you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Ethernet Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Dhanniel M.
Devi_Intel
Hi Grillobirillo,
Greetings~
Thank you for posting Ethernet Community.
Understand you encounter an issue with the system error related ESIF 1.0.70701.24404. Besides, have you check with Lenovo technical support regarding this issue. If no, appreciate you can check with Lenovo Technical support for further assistances too. As we assuming this need to fix with windows update along with BIOS and driver firmware update needed.
We will follow up after 3 business days in case we don't receive a response.
Thank you & Best Regards,
Devi
Devi_Intel
Hi Grillobirillo,
Greetings~
Regarding your community support case, we are following up to find out if you were able to complete the actions we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply.
Thank You & Regards,
Devi
Grillobirillo
hi Devi,
thanks for your interest, I contacted Lenovo as your suggestion, which checked if all the drivers are updated and then advised me to do a bios downgrade.
Unfortunately even after doing what was advised the problem persists.....
mg
IntelSupport
Community Manager
Hi Grillobirillo,
Thank you for your response.
To assist you further, please provide the additional details below.
Kindly help us with the internet advertisement model?
If possible, could you please provide the front and back pictures of the adapter?
And where you downloaded the driver (Ethernet: Ver. 12.19.2.60) and please share the link?
Vikas
Devi_Intel
Hi Grillobirillo,
Greetings~
Regarding your community support case with us, we are following up to find out if you were able to complete the actions we previously recommended.
Devi
Devi_Intel
Hi Grillobirillo,
Greetings~
Your issue is now considered resolve, therefore we are proceeding to close this ticket.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Devi
