We have X710 for 10GbE SFP+ in one of my products running on Linux 3.14, where we recently updated the driver to version 1.5.16.
After driver update we started getting a mesg as below:
[ 9.407133] i40e 0000:82:00.3: fw 4.22.27454 api 1.2 nvm 4.26 0x800014ab 0.0.0
[ 9.414503] i40e 0000:82:00.3: The driver for the device detected an older version of the NVM image than expected. Please update the NVM image.
Current firmware and driver:
root@abcd:/tmp/xl710_old# ethtool -i eth2
driver: i40e
version: 1.5.16
firmware-version: 4.26 0x800014ab 0.0.0
bus-info: 0000:03:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Now we refered to Intel support and came to know about NVM Update Utility. We downloaded latest one and tried to update the NVM image we got error, log below:
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.26.17.11
Copyright (C) 2013 - 2016 Intel Corporation.
./nvmupdate64e -l fileoutput.txt
Config file read.
Inventory
[03:00:00]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
EEPROM inventory started
Warning: VPD is not valid
Alternate MAC address is not set
EEPROM inventory finished
Flash inventory started
Flash inventory finished
OROM inventory started
Discovered OROMs: No OROMs discovered
OROM inventory finished
[03:00:01]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[03:00:02]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[03:00:03]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[130:00:00]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[130:00:01]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[130:00:02]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[130:00:03]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
Update
Creating backup images in directory: 08357107C9F0
OROM not present on device - skipping FLB backup
Backup images created.
Flash update started
Error: Can't preserve PBA. Not enough space on image (Device PBA size: 6, Buffer PBA size: 2)
Creating backup images in directory: 08357107C918
What we may be missing here ?
- Tags:
- Devices
Same problem here.
We have a bunch of Supermicro X710 4x10G SFP+ cards. They come wih FW 4.43 by default.
After upgrading to 5.02 (old firmware, revoked as buggy) and 5.04 (old firmware, revoked as buggy) we are unable to upgrade FW to latest 5.05.
It fails with "Error: Can't preserve PBA. Not enough space on image (Device PBA size: 256, Buffer PBA size: 6)".
Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter X710-4
# ./nvmupdate64e -l log1 -o log-update1
NVMUpdate version 1.28.19.4
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Ver. DevId S:B Status
01) Intel(R) Ethernet Converged Network 5.04 1572 00:001 Update
Adapter X710-4 available
02) Intel(R) Ethernet Converged Network 5.04 1572 00:002 Update
03) Intel(R) I350 Gigabit Network Connection 1.97 1521 00:006 Update not
available
Options: Adapter Index List (comma-separated), [A]ll, e[X]it
Enter selection:1
Would you like to back up the NVM images? [Y]es/[N]o: n
Update in progress. This operation may take several minutes.
Tool execution completed with the following status: An error occurred when updating a firmware module
Press any key to exit.
Config file read.
OROM will be updated with current combo image set for the adapter 'XL710'.
Inventory
[00:001:00:00]: Intel(R) Ethernet Converged Network Adapter X710-4
OROM verification started
OROM is up to date
[00:001:00:01]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
Device already inventoried.
[00:001:00:02]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[00:001:00:03]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[00:002:00:00]: Intel(R) Ethernet Converged Network Adapter X710-4
OROM is up to date
[00:002:00:01]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
[00:002:00:02]: Intel(R) Ethernet Controller X710 for 10GbE SFP+
<span style="font-family...
Seems to be fixed in 6.01 i40e firmware.
We were able to upgrade at least one card SM X710 4x10G from 5.02 to 6.01.
