Ethernet Products
5719 Discussions
Ethernet Controller (3) I225-V error 0xC00000E5
Julian35
Hi there !
I have recently received a Geekom mini PC with the ethernet controller indicated in the subject of this post.
I cannot connect to the internet using this port, although my cable seems fine : it is working with both my working station and a USB-C hub plugged on my new mini-PC.
Looking into the Events of the device, here is what I find :
Do you have any ideas on how to fix that problem ?
Some more info about my system :
Device name DESKTOP-I3473FK
Processor 13th Gen Intel(R) Core(TM) i9-13900H 2.60 GHz
Installed RAM 32.0 GB (31.8 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 11 Pro
Version 23H2
Installed on ‎26/‎10/‎2023
OS build 22631.2861
Experience Windows Feature Experience Pack 1000.22681.1000.0
Thanks !
Srri
Hello Julian,
My apologize 3for the inconvenience caused, please provide the following details.
  1. Please provide the exact problem encountered.
  2. Please help generate SSU logs for us to check the system. Please download the utility here: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for- windows.html?wapkw=ssu
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 working days. Thank you.
Srri
Intel® Customer Support
Julian35
Hi Srri !
Thx for replying. You'll find the logs file attached.
The exact description of the problem is that a working network cable, functionnal with my professionnal laptop's docking station, isn't providing any connection when plugged on my ethernet port. The strange thing is that the port seems to light up when the PC is on sleep (green light only). Pictures attached.
I also add that the cable is working when plugged on the ethernet port of the USB-C hub I use.
Thx for your help !
Srri
Hello Julian,
Hope you're doing well and safe there. I'm sorry that you're having trouble with your internet connection.
I would suggest first you to turn off your modem/router and leave it off for just a minute then turn it back on and check if fixes the issue
If steps above didn't work you may run network troubleshooter, use these steps:
Open Settings.
Click on Update & Security.
Click on Troubleshoot.
Under the "Recommended troubleshooting" section, click the Additional troubleshooters option.
Under the "Get up and running" section, select the Internet Connections troubleshooter.
Quick note: On Windows 10 version and earlier, the option is available within the Troubleshoot page.
Click the Run the troubleshooter button.
Select the Troubleshoot my connection to the Internet option.
Select the Try these repairs as an administrator option (if applicable).
Continue with the on-screen directions (if applicable).
After you complete the steps, the troubleshooter will run and fix any connectivity issues.
In the event that troubleshooter didn't work, try resetting the TCP/IP stack and clearing any DNS information on Windows 10.
Reset the network stack using Command Prompt by following these steps:
1. Open Start.
2. Search for Command Prompt, right-click the top result, and select the Run as administrator option.
3. Type the following command to reset the component that handles network requests and press Enter:
netsh winsock reset
4. Type the following command to reset the internet protocol stack and press Enter:
netsh int ip reset
5. Type the following command to clear the current networking configuration and press Enter:
ipconfig /release
6. Type the following command to reconfigure the network settings and press Enter:
ipconfig /renew
7. Type the following command to clear the DNS information cached and press Enter:
ipconfig /flushdns
Restart your computer.
Once you complete the steps, launch the web browser and confirm the internet is working.
8. If the steps above still doesn't work, reset all the network adapters, use these steps:
Open Settings.
Click on Network & Internet.
Click on Status.
Under the "Advanced network settings" section, click the Network reset option.
Click the Reset now button.
Click the Yes button.
After you complete the steps, the computer will restart automatically, and on reboot, you should now be able to connect to the internet.
Take note that this will reset all the network adapters installed on your computer to their factory defaults, you'll need to re-enter your password to connect to WIFI network. You'll need to reconfigure other networking software, such as VPN clients, if applicable.
Hope this helps.
Thanks and regards,
Srri_Intel
Srri
Hello Julian,
Regarding your case, we are following up to find out if you were able to complete the actions we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Srri
Intel Customer Support
Srri
Hello Julian,
Srri
Srri
Greetings Julian,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Thank You & Regards
Srri
Srri
Greetings Julian,
Thank You & Regards
Srri
