The documentation of the 700-series Ethernet controller indicates that the Receive Queue Length can be up to (8192 - 32) or 8160. Section 8.3.3.2.2 Receive Queue Context in FPM in 38.3.3.2.2 Receive Queue Context in FPM.pdf
However, the i40e Linux driver for the X710 Ethernet controller in the 6.6. kernel has a maximum size of 4096.
I'm mainly interested in hearing from Intel support if they have any concerns with increasing the maximum from 4096 to 8160 for the X710 controller?
Hello pjf,
Regarding your question I would highly suggest that you post in below link instead:
https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
As the issue will be needing more internal information to be provided.
Kindly let us know once you successfully posted in the embedded community site so we can proceed to close this case 06019340.
Nurhayati
I posted on the link that you provided. thanks.
Hello pjf,
Thank you for your reply.
With this we will proceed to close the case 06019340.
Please do not hesitate to contact us again if you have any further questions by submitting a new case.
Nurhayati
