Ethernet Products
5821 Discussions
Ethernet Driver
JackGrimes
I am using internet with LAN but in device manager there is no Intel(R) Ethernet Controller Driver I tried to download but it can't.
Mobo - Asus Tuf gaming B760m
CPU - Intel Core i5 12400f
Sazirah
Hi JackGrimes,
Thank you for contacting Intel Ethernet Communities.
May I know what model of Intel Ethernet that you are using? Also, did you bought it with the motherboard from Asus?
Sazzy_Intel
JackGrimes
I don't know the model of Intel Ethernet it not show in device manager.
LeonWaksman
From this page you can download all drivers for your board.  BTW, as you can see the LAN driver is for Realtek LAN rather than Intel's.
Leon
Simon-Intel
Hi JackGrimes,
Greetings! Thank you for contacting Intel Ethernet Communities.
Could you please confirm if you are using the card that came with the system or if it was an add-on?
If the card came with the system, you would need to contact Asus(OEM) for further support.
Simon
n_scott_pearson
@LeonWaksman, thank you for responding. I was about to post exactly that.
@Sazirah and @Simon-Intel, shame on you both; the first thing you should have done was look at the motherboard's spec sheet and answer this question yourself. I took me less than 30 seconds to do so.
Sazirah
Hi JackGrimes,
You may follow LeonWaksman's suggestion to visit OEM's website to get the Realtek driver since it is not Intel LAN.
For further information, we advise you to contact OEM Asus support as they will be more expertise in the product and will be able to assist you.
Sazzy_Intel
Sazirah
Hi JackGrimes,
Since we do not receive any response from you, we will be closing this thread from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Thank you for using Intel products and services.
Sazzy_Intel
