Ethernet Products
5736 Discussions
Ethernet Drivers never installed.
DAspl
I'll start by saying I think I've located the missing ethernet drivers from ASROCK's website, but when I run intel's setup wizard, my computer freezes. I've also tried using the Intel Driver Update utility, which also claims to find the drivers, but once I click install, it simply reads that it failed.
I also tried installing the latest chipset utility for intel still to no avail.
I should also mention I'm on the internet using some USB D-Link wireless adapter, I can't imagine its drivers are causing a problem, but at this point I'm open to ideas.
I'm currently running Windows 7 x64bit with an ASROCK z97 extreme 6 motherboard, Intel Core i7-4770K Quad Core processor.
I built the computer myself, and these are the only drivers that refuse to install.
Again, I believe I located drivers on ASROCK's website, but the intel driver install wizard makes my computer freeze every time.
st4
New Contributor III
Hi DuncoChunko,
Thank you for the post. Please get in touch with Asrock support for the customized driver as the driver provided by Intel si generic version, we cannot guarantee 100% compatibility.
rgds,
wb
