I am using Wireshark on a machine that has ( from the registry via regedit ):
DriverDesc : Intel(R) Ethernet Connection (2) I219-LM
and I added:
MonitorMode : 1 ( REG_DWORD 32 bit )
as per Intel help forum:
https://communities.intel.com/thread/51323 https://communities.intel.com/thread/51323
That did not help
Problem is that Wireshark sees all the traffic to and from the machine it is on but not between two different machines; they are connected with a hub.
In Capture - Options - Input, the Promiscuous box is checked.
Has anyone encountered this? Do you have a remedy? Is the Driver filtering out those other packets?
Boyd
- Tags:
- Intel® Ethernet
Hi BoydMills,
Thank you for posting at Wired Communities. Please refer to http://www.intel.ph/content/www/ph/en/support/network-and-i-o/ethernet-products/000007255.html http://www.intel.ph/content/www/ph/en/support/network-and-i-o/ethernet-products/000007255.html as this has to do with the network management agent or other software (such as "Network sniffer").
Just to double check both machines integrated with the same ethernet controller I219-LM ?
regards,
sharon
Thank you Sharon.
The link did point me to the newest drivers ( I month old! ) for the Ethernet adapter. I installed it.
https://www.intel.sg/content/www/xa/en/support/network-and-i-o/ethernet-products/000005498.html My Sniffer Isn't Seeing VLAN, 802.1q, or QoS Tagged Frames
Gives a list of devices ( e1d ) and what "magic" keyword: MonitorMode value 1 to add to the registry.
I had already done that but did it again.
I do not use vlan so that is a non issue.
The other units are not using the same Ethernet adapters.
The "hub" is just that: a hub. Dumb as a stick. A Bell 2000 device. The Ethernet hub part of the device is not programmable. Plus is does pass through of other protocols such as 'BACnet over Ethernet' that are not routable.
Still my sniffer "wireshark" can only see data that is sent to or from the pc on which it runs.
Please advise.
Boyd
Hi BoydMills,
Thank you for the update and additional information. Let me further check.
Sharon
Hi BoydMills,
Just to double check if you have checked with Wireshark as the software can't capture the packets, understand the promiscuous is already enabled. Here is the reference information you may refer to: https://wiki.wireshark.org/HubReference (Please note this is third party website for your reference only, Intel has no control over the content therein).
Please feel free to update met.
sharon
Hi BoydMills,
Please feel free to update me if further assistance needed?
Sharon
