Ethernet Products
5821 Discussions
Ethernet port burn or Can it be fixed ?
EStam1
Details :
Ethernet port of motherboard is not working , both 2 lights of port are always off .
Device Manager : Intel Ethernet Connection I219-V cannot start _ code : 10
It also says that operation failed _operation asked failed
Motherboard : Asus H170M-PLUS
Cause : Lighting
Whole setup is connected to a surge arrest .
How I can be sure that the ethernet port is not functional ?
Can it be fixed ?
Like reseting CMOS or in any other way ?
If not what do you recomend ? Buy just a new usb to ethernet controller or a new Network Card Controller ?
If need more details ask for .
Thank you .
Hi Estamos,
Thank you for posting at Wired Communities. Based on what you described, if the ethernet I219-V on the Asus board has physical or hardware problem, you need to contact the board vendor which is Asus in your case, as the I219-V is part of their motherboard, they are in best position to check on the hardware and provides warranty replacement if the board is eligible for replacement. You may refer to below link for the Intel network connection support
https://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006628.html?wapkw=oem+network
Hope this clarified.
sharon
Hi Estamos,
Just to double check, as you mentioned the whole setup is connect to surge arrest and there is no lights when you try connect the cable, have you tried the following:
1) Connecting the I219 ethernet to a switch?
2) Have you tried testing on different ports and cable?
3) Are you able to ping the network adapter?
4) Did you try re-installing the driver?
sharon
Hi Estamos,
Please feel free to provide the information for me to better check on your concern.
Sharon
Hi Estamos,
You can check with your board vendor what are the compatible network adapter for your system in case you plan to purchase an external network adapter. It is recommended to check with your board vendor for the validated/compatible parts. Thank you.
Sharon
