When we use the iavf-4.13.3 to test the VF functional rx checksum on the E810.
we found the follow issue:
when PF tests rx checksum. the ethtool command shows error packets and iproute2 also shows the number of errors.
However, when VF tests rx checksum, no error packets are displayed in the ethtool command, and iproute2 does not display the number of errors.
- OS and Kernel Version (output of uname -a)
[root@localhost ~]# uname -a
Linux localhost.localdomain 6.6.0-28.0.0.34.oe2403.x86_64 #1 SMP Mon May 27 22:22:46 CST 2024 x86_64 x86_64 x86_64 GNU/Linux
[root@localhost ~]#
- NIC Firmware Version
[root@localhost ~]# ethtool -i ens5f0np0
driver: ice
version: 1.16.3
firmware-version: 2.50 0x800077a8 1.2960.0
expansion-rom-version:
bus-info: 0000:98:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
[root@localhost ~]#
- Driver Version
driver: ice
version: 1.16.3
supports-test: yes
[root@localhost ~]#
[root@localhost ~]# ethtool -i ens5f0v0
driver: iavf
version: 4.13.3
firmware-version: N/A
bus-info: 0000:98:01.0
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
[root@localhost ~]#
- How the VF was Created (SR-IOV settings, virtualization details if applicable)
[root@localhost usertools]# echo 1 > /sys/bus/pci/devices/0000\:98\:00.0/sriov_numvfs
Hi barry shang,
Thank you for reaching out to the Intel support. We acknowledge receipt of your concern and want to assure you that assisting you is our top priority. To effectively troubleshoot the issue you're facing, we require some additional information from your end.
Could you kindly provide the following details?
1.Kindly share the complete Ethernet card and system details.
2.Please confirm whether the Ethernet card was purchased separately or came pre-installed with the system.
3.Could you please provide front and back pictures of the adapter, including label marking details?
Your prompt response with this information will greatly assist us in diagnosing and resolving the issue as quickly as possible.
We look forward to hearing from you soon.
Poojitha N
Thanks for your support:
The Ethernet card is E810, the OS is openEuler-24.03-LTS which shipped the kernel 6.6.0-28.0.0.34.
The Ethernet card was purchased separately.
Sorry, the card insert in the lab machine. I can't get the picture. but I can confirm that it is a general issue,
you can use the E810 card to reproduce the issue on any linux machine with any iavf version.
Hi barry-shang
Greetings for the day!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
We appreciate your understanding!
Poojitha
Hi barry-shang
Poojitha
Hi barry-shang,
Thank you for sharing the details. We kindly request you to share the SSU logs using the link below. This information will help us review the complete details and provide you with an update.
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Poojitha N
why do you request the ssu logs ? Are you try to reproduce it ? I have told you this issue can reproduce easily. now I don't have the environment. so I can't provide any infomation.
In addition, this is a generial issue. if you want to reproduce this issue. you can use any linux shipped with your iavf driver.
Hi barry-shang,
Poojitha
Hi barry-shang,
Poojitha
