I am trying to discover caveats in connecting two i210s to a port-expanded Atom using a Pericom/Diodes x2 to dual x1 switch. (PI7C9X2G304ELQZXAE)
Pericom seems to suggest that DMAs are not supported with most of the switches (certainly all of their low port count switches).
There is also a specified 150nS latency through the PCIe switch.
Is this PCIe switching possible with network NICs like the i210?
- Tags:
- Connected
Hi Jeff_M,
Thank you for posting in Wired Communities. I will need to check on this inquiry.
Sharon
Hi Jeff_M,
Further checking, as this is embedded component, please post your inquiry at https://embedded.communities.intel.com/
Here is the I210 datasheet for your reference
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-dat...
Sharon
