Ethernet Products
5607 Discussions
FM1000 "PMD: eth_fm10k_dev_init(): switch is not ready" error with dpdk
anuradhalk
I'm trying to run dpdk on Intel FM10000 NIC. I have installed "fm10k" driver and I can see my NIC on ifconfig. I have bound the interface to igb_uio and tried to run testpmd and following error occurs,
As per DPDK documentation on https://doc.dpdk.org/guides/nics/fm10k.html , I need to install another switch driver to get FM10k work with dpdk I think. Kindly let me know if this is the problem and how can I obtain the switch driver.
Anuradha
Mike_Intel
Hello anuradhalk,
Regarding your inquiry, please contact our DPDK support. They should be able to help you with your concern. Kindly open the link below and click "Access and Log In" to contact the DPDK support.https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Under Contract to Intel Corporation
anuradhalk
I have contacted my NIC manufacturer and obtained a proper driver and everything is working good now.
However,  I need to create 4 VFs of my FM10000 NICs using SR-IOV and share 2 of them to a VM and other 2 to the host computer. I use Qemu/KVM for VM creation. I have set  intel_iommu=pt and I can bind 2 VFs to host using fm10k driver. However I am unable to bind rest of the 2 VFs to vfio-pci driver to share them to VM. The following kernel error is occurred upon binding,
vfio-pci: probe of 0000:da:00.1 failed with error -22
Kindly let me know if there is a quick fix for this or I will add this as a new question.
Anuradha
Mike_Intel
Hello anuradhalk,
Before we proceed, let me clarify the following information first.
  1. Are you building or designing a custom system?
  2. Regarding the new question, is it still related to DPDK?
Michael L.
Mike_Intel
Hello anuradhalk,
I am just sending a follow up regarding the information that I asked below for me to further help you.
Michael L.
Mike_Intel
Hello anuradhalk,
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Michael L.
