HI
I set 4000-4049 vlan filter to a vf:
for(vlanindex = 4000;vlanindex<=4049;vlanindex++)
diag = rte_eth_dev_vlan_filter(dev->port_id,vlanindex,1);
if (diag) {
VLOG_INFO("Interface %s vlan(%d) setup error: %s",
dev->up.name, vlanindex, rte_strerror(-diag));
return diag;
2017-07-24T04:48:34.260Z|00076|dpdk|ERR|PMD: ixgbevf_vlan_filter_set(): Unable to set VF vlan
2017-07-24T04:48:34.260Z|00077|netdev_dpdk|INFO|Interface dpdk-trunk-0000.01.10.2 vlan(4003) setup error: Network is down
The error is in a random vlan filter set
dpdk version: 16.11
Hi Genius_cdj,
Thank you for writing to Wired Communities. Please be informed for all Intel® DPDK questions and technical problems including those regarding the Ethernet* Controllers, you may report through the Intel® Premier Support site
http://premier.intel.com/premier or access IBL account. Click the Intel® Premier Support link to enter issues under the Product Name "Data Plane Development Kit (DPDK)". This will forward to the appropriate support
team.
Hope the above information help.
sharon
