Ethernet Products
5603 Discussions
Failover not working on X520 NIC with ixgbevf driver
GORaw1
I have the following setup:
  • Virtual environment with Openstack with Intel X520 NIC
  • Hypervisor using ixgbe driver
  • Virtual machine using ixgbevf driver (version 4.6.1) on Red Hat Linux 7.6
  • VM interfaces are bonded in active-standby mode on ingress and egress
In normal state everything is fine, the bond interfaces are operational, e.g.:
$ more /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: None
Currently Active Slave: eth2
MII Status: up
MII Polling Interval (ms): 0
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: eth2
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: fa:16:3e:07:55:40
Slave queue ID: 0
Slave Interface: eth3
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: fa:16:3e:7c:dd:ab
Slave queue ID: 0
However when the primary interface ens2f0 is taken down on the hypervisor, failover does not occur to the eth3 interface on the VM and traffic fails:
Primary Slave: None
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
MII Status: up
Speed: Unknown
Duplex: Unknown
Slave queue ID: 0
MII Status: up
Speed: 10000 Mbps
Duplex: full
Slave queue ID: 0
eth2 is still marked as UP by the bonding module and as the currently active slave even though the link is down:
$ ethtool eth2 | grep detected
Link detected: no
There aren't any errors logged on either VM or hypervisor, except for:
On the VM:
kernel: ixgbevf 0000:00:06.0 eth2: NIC Link is Down
kernel: ixgbevf 0000:00:08.0 eth4: NIC Link is Down
On the hypervisor
kernel: ixgbe 0000:37:00.0: removed PHC on ens2f0
When the ens2f0 interface on the hypervisor is brought up again, everything is fine, i.e. the bond appears to work only if the original primary interface is running.
Are there any issues with this driver in this setup (though it is the latest driver version), or could there be a configuration which is not applied?
Greg
Caguicla_Intel
Hello Greg,
Kindly provide the following details for us to check on your query.
1.) Exact model of the adapter. Please also provide the PBA number for us to double check on it. You may refer to the link below on where to find the PBA.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-io/ethernet-products.html
2.) Please share the ixgbe driver version used and kernel version information
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
GORaw1
Hi Criselle,
Adapter model is:
Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
Subsystem: Intel Corporation Ethernet Server Adapter X520-2
PBA: E68793-006
ixgbe driver version:  5.6.3
Hypervisor:
Red Hat 7.6
kernel version: 3.10.0-957.5.1
VM:
Red Hat 7.5
kernel version: 3.10.0-862.11.6
Greg
Caguicla_Intel
Hello Greg,
Thank you for providing the requested details.
After checking, it is best to try the channel bonding configuration in kernel version 4.x and up with latest driver version as there are many features from kernel 3.10 that has been backported by Red Hat which hardly resemble the actual versions release from kernel.org.
Let us know if you have additional questions and clarifications on this request.
Crisselle C
Caguicla_Intel
Hello Greg,
Good day!
Please let us know if Failover is now working with your setup. We would highly appreciate if you can send us an update for the status of this request.
We hope to hear from you soon.
Crisselle C
GORaw1
Hi Crisselle,
Do you mean upgrading the kernel to version 4.x or later? That is not an option with this particular deployment.
Does bonding and failover not work with the ixgbe/ixgbevf driver for Red Hat kernel versions 3.x?
Greg
Caguicla_Intel
Hello Greg,
Yes. We hope you don't mind sharing more details why upgrading the kernel to 4.x and later is not an option with this particular deployment. This would help us to better understand and further check this request.
Awaiting to your reply.
Crisselle C
Caguicla_Intel
Hello Greg,
Good day!
We'd like to follow the requested details above for us to forward it to our engineering team and further check on this request.
Crisselle C
GORaw1
Hi - this is for a particular customer deployment which is on Red Hat kernel 3.x and upgrading the kernel version is not possible as it is tied to versions of other software.
Can you confirm if failover is supported for this NIC card on the existing kernel version?
Greg
Caguicla_Intel
Hello Greg,
We appreciate your prompt reply.
Please allow us to further check on this. Rest assured that we will get back to you within 1-3 business days.
Hoping for your patience.
Crisselle C
Caguicla_Intel
Hello Greg,
Good day!
Please be informed that we are still looking into your request. We hope you don't mind providing additional information below which will be helpful for us to further check.
1.) Do you have any FCOE configuration enabled? Disabling FCOE stuff could fix some bonding issues.
2.) Have you tried posting on Linux/Sourceforge forums regarding this issue?
We look forward to your response.
Crisselle C
Caguicla_Intel
Hello Greg,
I hope you're doing great!
We'd like to check if you have Red Hat account? If yes, kindly visit the link below that might be helpful to your issue resolution.
https://access.redhat.com/solutions/27863
Looking forward to hear an update from you.
Crisselle C
GORaw1
Hi - thanks for the reply. I will check this link and see if it is helpful.
Greg
Caguicla_Intel
Hello Greg,
You are welcome, appreciate your response.
We hope that the provided link will be helpful to this issue. We will wait for your update once you have checked the link above.
Looking forward to hear from you.
Crisselle C
Caguicla_Intel
Hello Greg,
Good day!
We'd like to check if you have visited the link that we provided. We would highly appreciate if you can share an update for the status of this request.
Awaiting to your response.
Crisselle C
Caguicla_Intel
Hello Greg,
How are you today?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups.  Should you have any other concerns or assistance needed in the future, please do not hesitate to post a new question.
Crisselle C
