Ethernet Products
4873 Discussions
Get I210 Intel Driver Source Code
DMuel6
Hello Community,
we are creating a software system which uses PTP. PTP needs timestamping support through hardware. The Intel Controller I210 has this functionality. But our problem right now is, that the Intel Driver does not support timestamping. This is an major issue for us.
We found following post:
https://forums.intel.com/s/question/0D70P00000692BQSAY/i210-windows-driver-source-code?language=en_US
My question now is, where can we get the source code, so that we can add the timestamping functionality, which your hardware supports but your software does not.
Thanks in advance.
DM
AlHill
The process would be the same as in the thread you linked to.
Doc
DMuel6
Firstly thank you for your lighting response.
We already got a CNDA. Our CNDA Number is cnda038790.
Now we would like to receive a PM with the associated source code download link for the distribution option 3 (Source code for modification with distribution of object code) as can be seen in the linked topic.
Is that possible?
Our target OS would be Windows 10.
DM
AlHill
One of the Intel support engineers will assist you.
Doc
Caguicla_Intel
Hello DMuel6,
We've sent personal message to you, kindly check your inbox.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
