Ethernet Products
5779 Discussions
Gigabit doesn't work on Intel I219-V
Hi all. Few days ago I bought the motherboard MSI Night Elf (network adapter Intel I219-V).
I Have a problem with gigabit internet. It doesn't work. In properients i see 1 GBPS, but on speedtest.net i see only 100 mpbs.
It's not a problem with cable or router, because in the past i had not problem with it (before that i have a motherboard ASUS P5Q3 and saw real speed 800 mbps).
I hope to solve this problem and hope for your help.
Thanks a lot!
Hi BrovarySecurity,
Thank you for posting your query in Wired Ethernet Communities.
I'd suggest other means of testing such as downloading, transfer files within local area network or use another device to connect to your router for further isolation.
Sharing the latest driver available in our Download Center for i219-V, you may also contact MSI support as our network adapter is integrated to their system, they may have altered the features, incorporated customization. There might be known configuration for your board with the specific environment.
https://downloadcenter.intel.com/search?keyword=i219-V
regards,
Vince
Hi BrovarySecurity,
We'd like to check if you still need assistance regarding i219-V.
regards,
Vince
