Ethernet Products
5736 Discussions
Gigabyte Z97-D3H+Intel X520-SR2 fail to enable VFs
XSun10
Hi, I try to create VFs with Intel X520-SR2 on Gigabyte Z97-D3H.
I enable Intel Virualization Technology and VT-d in BIOS setting and add boot parameter "intel_iommu=on".
I use PF driver (ixgbe driver version: 4.0.3) and VF driver (ixgbevf driver version: 2.16.1) on Ubuntu 14.10 with kernel version of 3.16.0.23
After insert ixgbe and ixgbevf module, I fail to see VFs with lspci -n command.
Can anybody help me? Thank you!
XSun10
Add boot parameter: pci=assign-busses
Then VFs can be seen.
Thank you!
ANDREY_V_Intel1
Are you enabling VFs on your system?
You should load the driver with sriov_numvfs parameter like this:
echo 4 > /sys/class/net/device name/device/sriov_numvfs
Please refer to the SR-IOV configuration guide for more details: http://www.intel.it/content/dam/www/public/us/en/documents/technology-briefs/xl710-sr-iov-config-guide-gbe-linux-brief.pdf http://www.intel.it/content/dam/www/public/us/en/documents/technology-briefs/xl710-sr-iov-config-guide-gbe-linux-brief.p
XSun10
Hi, Anvanster, thank you for your reply
I did try to enable VFs as you described, echo 4 > /sys/bus/pci/devices/0000\:05\:00.0/sriov_numvfs
but I met the following error in terminal.
write error: cannot allocate memory
Dmesg will show: SR-IOV: bus number out of range.
I tried to add "pci=realloc=on/off" to boot parameters, but still met this error.
XSun10
Thank you!
ychen105
hi , i'm confused with the same question as you describe ,however i can't create it correctly . could you help with some further instruction? my email is mailto:enwplan001@163.com enwplan001@163.com
