Ethernet Products
5534 Discussions
Have ipmi over lan any limitations ?
SB17
Hi
May any clarify one question ?
Why the Inel continues to maintain a separate ipmi port, and does not do all ports combined with ipmi and gigabit Ethernet? ipmi over Ian has an some limitations?
P.S. I have server sj2000
or redirect me if I not guess the forum
Patrick_K_Intel1
I've a somewhat dated, yet still relevant document on the Sideband interface available here: http://www.intel.com/content/www/us/en/ethernet-controllers/sideband-technology-appl-note.html Intel® Sideband Technology: Server Manageability Interfaces.
We provide some common filters that are built in, such as the IPMI port. However you can filter on anything you like, including a dedicated MAC address, which would allow your BMC to do anything it likes. You can filter on any port, ethertype,vlan tag etc that you wish, is fully configurable.
The common filters are there for legacy reasons, from back when the BMC and the host always shared a MAC address; while this design is not used as much as it was 10 years ago, it is still a valid usage model and as such we continue to maintain those build-in capabilities.
I hope this helps.
- Patrick
Patrick_K_Intel1
I hope this helps.
- Patrick
