I am trying to set up VLANs on one of our PCs. That PC is based on a DG33FB motherboard with a 82566dc-2 NIC running Windows 10. The properties of the NIC show VLAN and Priority enabled but I unable to select the VLAN itself. I understand that that I need advanced network services ANS) installed with the NIC driver.
The driver now in use is a Microsoft one without the ANS support. So I downloaded the latest PROSET driver, ran it for it to report no Proset NIC found. So I tried a manual install unpacking the PROSET driver and set the install point to the PRO1000 folder and on trying to install it ended up with Windows report that the best driver was already installed. If I search the driver files I see this NIC listed in several .inf files in NDIS62 & 64 and if I select either of these (using pick from list option) I am presented with a list of models (I218-LM etc) but not my NIC.
Any help suggestions much appreciated.
Hi Alan,
Thank you for posting in Wired Ethernet Community.
Please be informed the 82566DC-2 Ethernet Controller has already been discontinued since 2011 and there's no plan for driver and software update.
In case you plan to purchase Intel(R) Network Adapter, please refer to the links below.
Intel(R) Ethernet Adapters supported in Windows 10. Look for adapter model with "Yes" in the "Full Support" column.
https://www.intel.co.uk/content/www/uk/en/support/articles/000020905/network-and-i-o/ethernet-produc... https://www.intel.co.uk/content/www/uk/en/support/articles/000020905/network-and-i-o/ethernet-produc...
Locate a Reseller:
https://www.intel.co.uk/content/www/uk/en/products/find-a-reseller.html https://www.intel.co.uk/content/www/uk/en/products/find-a-reseller.html
Kindly let us know if you need further clarification about this inquiry so that we can better assist you. Thank you.
Vince T.
Intel Customer Support
Agent under contract to Intel
Hi Alan,
We'd like to check if you still need assistance regarding your concern.
Vince T.
